10
This discussion topic has been answered Discussion topic: Old Sky TV Box
This message was authored by: ldg123
Old Sky TV Box
Hello,
I cancelled my Sky TV Subscription several months ago. What can I do with the old Sky Box? Also, Do I need to contact a specialist to remove the wire that leads to the Sky Dish through the wall?
Many thanks.
This message was authored by: Mark39 Answer
Re: Old Sky TV Box
The box is yours to do with as you wish. You can remove the cable (and the dish) yourself if you wish.
Re: Old Sky TV Box
Avatar for ldg123
Re: Old Sky TV Box
Thank you for the quick reply.
Re: Old Sky TV Box
@ldg123
Perhaps worth noting that a Sky+ / Sky+ HD box without a subscription will function as a basic Freesat receiver for viewing free-to-air channels.  A Sky dish, Sky+ LNB and cabling can also be used with a Freesat recorder, including the new '4K' models (although no Freesat is currently broadcast in UHD)
This message was authored by: ljmm1967
Re: Old Sky TV Box
If your really done with satellite tv then you can ask most electricians to remove it all. As for the old box the sky/+/hd and first gen Q boxes were owned by consumers. next gen Q boxes are rented and you will need to send them back to sky when you cancel. You'll find this information in your contract.
Re: Old Sky TV Box
@ljmm1967 do you have a source for this information as I don't believe it to be correct, no Sky q equipment of any version or age has ever been sold direct to customers to my knowledge
@TimmyBGood do you have any knowledge of this happening?
Re: Old Sky TV Box
Early on, some Q Hubs were 'sold'.  Q television boxes never were.
Re: Old Sky TV Box
No, nor do I.
Re: Old Sky TV Box
ALL Sky Q boxes regardless of age are owned by Sky, Sky have NEVER sold Sky Q boxes to the customers they have always been rented
Re: Old Sky TV Box
That was my understanding also 🙂
Re: Old Sky TV Box
@SKY1992bf You are 100% correct no Q boxes are owned by the customer they are all loaned to the customer by Sky and therefore need to be returned
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
