2
This discussion topic has been answered Discussion topic: No sky signal
This message was authored by: naymac
No sky signal
My sky is not receiving satellite signal so annoying can this be fixed
This message was authored by: Mark39 Answer
Re: No sky signal
Try restarting your Sky box, if,you haven'talready, by switching off at the plug for 4 minutes. Failing that, unless you have Sky Protect, you'll have,to get a local satellite installer to come out to take a look.
Re: No sky signal
Re: No sky signal
Please Note: Sky+ is now a legacy service that Sky are winding down
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
