Discussion topic: No signal
This message was authored by: Trevor52
No signal
Just had a visit from our window cleaner and now we do not have signal
Re: No signal
@Trevor52
No signal or no satellite signal, they are different?
Re: No signal
No signal? Or no satellite signal?
If it's the latter, it's possible that the window cleaner has disturbed the dish. Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect, so you'll need to contact a local satellite engineer to take a look.
Alternatively now might be a good time to consider upgrading to Sky Q. Any dish or cabling issues will be addressed as part of the Sky Q installation at no additional cost to you.
