Discussion topic: No signal
This message was authored by: Carol+Haslam
No signal
No signal un plugged everything and got a electric shock so it's dangerous
Re: No signal
No Signal or No Satellite Signal?
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Re: No signal
Where did you get an electric shock from?
Avatar for Carol+Haslam
Re: No signal
I am so angry we have a live wire at the back of the tv that connects to sky dish,my son in law got a bad electric shock
Re: No signal
I don't know how that could have happened, but commonsense suggests as a precaution that you unplug your Sky box and stop using it, if you haven't already done so.
Re: No signal
How rude and patronising,we are two pensioners that have been left with no tv for 10 days already,i have phoned numerous times and e mailed so what do you suggest we do ,my husband is poorly we need the tv as we can't go out,my husband hasn't long been out of hospital,this is a disgrace
Re: No signal
@Carol+Haslam  A Satellite cable carries a maxiumum of 18volts, not enough for a "massive shock"
In fact no worse than a static electricity shock.
Re: No signal
....and carries no voltage at all unless it's connected to a Sky box.
Re: No signal
Nobody has been 'rude and patronising', just perplexed. What have Sky said?
Re: No signal
@Carol+Haslam  If you have Sky+ and  is no longer supported by Sky, so what did they say when you called?
This message was authored by: SpaceSparkie
Re: No signal
Posted by a Sky employee
Hi @Carol+Haslam
I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Sarah
Community Moderator
This message was authored by: Greenfingers001
Re: No signal
Thanks for escalating this. We’ve sent @Carol+Haslam an invite to chat.
Please be aware conversations automatically close if there is no response within 48 hours.
