3
This discussion topic has been answered Discussion topic: No signal message from Sky+HD box
This message was authored by: Mickswann
Sky+HD putting out message "no signal". Tried turning off and resetting to no avail checked signal via settings which shows no signal at both inputs . Box plays previously recorded programmes ok. What can I do please ?
Avatar for Mickswann
This message was authored by: Mickswann Answer
Re: No signal message from Sky+HD box
Issue resolved by local repairman - broken bracket holding LNB .   LNB refixed all working now !
No Signal or No Satellite Signal?
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentFAQs: Sky Glass Sky Stream Sky Go Sky Plus
Be warned - that's just temporary. In the absence of a signal from your satellite dish, it will eventually also refuse to allow access to the recordings in your Planner.
