Discussion topic: No signal
Message posted on 10 Apr 2025 10:13 AM
No signal
No signal being received since yesterday box has been re started several times and nothing
Message posted on 10 Apr 2025 10:21 AM - last edited: 10 Apr 2025 10:21 AM
Re: No signal
If that's no satellite signal, there's a problem most likely either with your dish or cabling. Unfortunately Sky no longer support Sky+ equipment unless you have Sky Protect, so you'll need to engage a local satellite engineer to take a look. Or alternatively now might be the time to consider upgrading to Sky Q. Any dish issues will be corrected without additional cost to you if you upgrade.
