Discussion topic: No signal
This message was authored by: Active
No signal
No signal and can't use planner or on demand
Re: No signal
I assume that's no satellite signal. Is this related to your other post about compensation? Have you reported it to Sky? What did they say?
Re: No signal
I guess yo mean No Satellite Signal
"No Satellite Signal" usually indicates an issue with one or more of the following:
• The Dish is misaligned
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
