Discussion topic: No signal sky +
This message was authored by: Helen183
No signal sky +
No signal
Re: No signal sky +
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
Re: No signal sky +
A no signal message is coming from your TV.
A no satellite signal is being produced by your Sky+ box.
So what one are you seeing ?
