Discussion topic: No satellite signal
This message was authored by: Peterbull27
No satellite signal
I have two sky boxes. One is working fine but the other has satellite connection problems. Currently not working and cannot record or view F1 etc but the second box is fine
Re: No satellite signal
"No Satellite Signal" is an error generated by your Sky box, it has nothing to do with broadband (Internet connectivity) and usually indicates an issue with one or more of the following
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
