Discussion topic: No satellite signal
Message posted on 19 Nov 2025 11:09 AM
No satellite signal
Hi since Saturday I have been unable to access my Hmdi 1.
the message I keep getting is your sky+hd isn't getting a satellite signal.. every day I have reset and it won't initialise. This issue has been since open reach fitted my new box outside. An appointment for 8 December has been allocated for the fibre broadband to be fitted. Please help
Message posted on 19 Nov 2025 11:18 AM
Re: No satellite signal
I'm afraid Sky no longer support Sky+ and Sky+HD set ups (where you've posted).
You'll need to employ a local satellite engineer at your own expense to check / realign / repair / replace the dish, or perhaps the LNB if that's the problem.
If you have Sky Protect cover through Domestic and General Insurance you can call them but a customer previous posted on here stated they wouldn't send an engineer - but they did offer the customer £65 towards arranging one themselves.
The alternative is contacting Sky to upgrade to Sky Q or change to Glass / Stream.
Message posted on 19 Nov 2025 11:28 AM - last edited: 19 Nov 2025 11:29 AM
@Moo-moo Your Sky box won't initialise because it's not getting a signal from your dish. See @Daniel0210's post for what to do to fix it. It has nothing to do with your fibre installation, unless the installer cut your dish cables.
