Discussion topic: Sky is not working it says that the box is initialising
This message was authored by: Reggie49
The box has been initialising for 4 days can you please send me information to get the box working
Re: Sky is not working it says that the box is initialising
"No Satellite Signal" is an error generated by your Sky box, it has nothing to do with broadband (Internet connectivity) and usually indicates an issue with one or more of the following
  • The Tuners in the sky box
  • The plugs on the cables
  • The cables themselves
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
@Reggie49 your Sky box is stuck at initialising because it's not getting a signal from your dish. See @Annie+UK 's post for what to do to fix it.
