Discussion topic: No satellite reception
This message was authored by: Jonny25
I have no signal. Phoned sky they did their remote checks couldn't resolve the issue so said they'd sent a new card and that it would arrive today. Needless to say it hasn't. Usual sky customer care. (If they can't sell you something then they couldn't give a **bleep**) anyone know how to resolve the issue?
Re: No satellite reception
If you're seeing a 'no satellite signal' message, a replacement Viewing Card is unlikely to help. It's more likely to be an issue with your dish or cabling.
Unfortunately Sky no longer provide engineer support for Sky+ boxes unless you have Sky Protect. You'll need to engage a local satellite installer to take a look for you.
Alternatively now might be themtime to upgrade to Sky Q. Any dish issues will be put right at no additional cost to you, as part of the Sky Q installation.
The viewing card does not cause a "No Satellite signal" error, so a replacement is pointless!. "No Satellite Signal" is an error generated by your Sky box, it has nothing to do with broadband (Internet connectivity) and usually indicates an issue with one or more of the following:
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
I am NeurodivergentMy Sky FAQs : Go Stream Glass Plus
