Discussion topic: No satellie signal
This message was authored by: Sue251208
No satellie signal
Hi, our sky has no  satellite signal as of last night
Re: No satellie signal
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q, Sky Glass and Sky Stream
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
If you've restarted the box by turning off at the plug for 4 minutes, and the problem persists,  it's most likely because of a fault with your dish setup. Sky no longer provide engineer support for Sky+ boxes unless you have Sky Protect,  so you would need to engage a local satellite installer to come and take a look
