1
This discussion topic has been answered Discussion topic: No satalite signal on TNT Sports only
This message was authored by: Margaret112
On TNT Sports I have a no satalite signal and code 25.  Have tried re-tuning still the same.   Any ideas
This message was authored by: Mark39 Answer
Re: No satalite signal on TNT Sports only
The cause is most likely a slight dish misalignment. Unfortunately Sky no longer provide engineer support for Sky+ equipment unless you have Sky Protect, so you'll need to contact a local satellite engineer to take a look.
Alternatively now might be a good time to consider upgrading to Sky Q. Any dish or cabling issues will be addressed as part of the Sky Q installation at no additional cost to you.
