Discussion topic: No internet connection to sky
This message was authored by Laura289 This message was authored by: Laura289
There is no internet connection to my sky box
Re: No internet connection to sky
@Laura289  Which Sky box do you have?  Sky+HD, Sky Q or Sky Stream
Laura289
Sky HD I think
This message was authored by Annie+UK This message was authored by: Annie+UK
Reboot your router then your Sky box
Note: I am Neurodivergent, Hardware: Sky+HD LG UHD TV Xbox Series X Amazon Fire HD
My Sky Frequently Asked Questions:PlusGlass / Stream
Laura289
I have tried that and it still doesn't work, will connect for a couple of seconds and then looses signal again.  Can't watch any apps or download anything from catch up
You have posted in the Sky Plus forum, it sounds like you don't have Sky Plus if you are running apps on your box. which system do you have, so I can move this thread if need be?
This message was authored by Mark39 This message was authored by: Mark39
@Laura289 is your Sky box connected to a satellite dish?
Laura289
Yes it is
I assume you have Sky Q, then, as Sky+ has no apps as @Annie+UK posted. I'll move your post to the Sky Q forum
