This discussion topic has been answered Discussion topic: No internet connection Sky HD+
Message posted on 31 May 2023 01:07 PM
Currently on full fibre and using skyhd + I have rebooted modem and Sky box and still having the following issues
certain items on the Home Screen ie Lyle Lyle crocodile if I press this I get the message there appears to be an issue with your broadband at this moment, yet when I press White House plumbers it works.
I can search for a programme to look for to record ie dads army and all the suggestions come up but when I press select I get the message there appears to be an issue with your broadband at this moment
I have tried everything and am wondering if anyone else is having the issue or if it's isolated or if it's a sky issue and it has only happened today and my internet is working fine and I have turned off and rebooted both router then sky box and still nothing
hope someone can help otherwise I will have to phone ......
Message posted on 31 May 2023 03:25 PM
UPDATE
NOW RESOLVED
it's started working properly again and it did update itself I don't know if that's the reason or wether it was a glitch but all working on now
Message posted on 31 May 2023 01:34 PM
Re: No internet connection Sky HD+
Does it affect particular channels?
Message posted on 31 May 2023 01:39 PM
No the channels are fine but I can search programmes on the search bar but when I press to look at episodes or set a recording or reminder it states there is a problem with the broadband at this time
UPDATE
NOW RESOLVED
