Discussion topic: Need help to get a power adapter for the SC201 wireless receiver
This message was authored by: no1phil
With full fibre being installed soon I need to source a new power adapter for my SC201 wireless receiver as there is an active mutiroom subscription. I was using one but it is giving me issues and turns on and off intermittently. It's a problem with the power adapter. What I need to know is the size of the connection and what power of adapter I should get. Moving to SKY Q isn't an option and running a cable to the router is also out of the question due to placement of the box from the router. Many thanks in advance.
This message was authored by: HeathHayle
Re: Need help to get a power adapter for the SC201 wireless receiver
unfortunately sky doesnt sell sky+ equipment or accessories anymore so you would have to source one else where if you use ebay there might be one on there
= Sky+ SD boxes x4 (pace bskyb 3100) ===
if you dont manage to source a power supply you would invest in ethernet home plugs
Or a network Access Point for WiFi connection with a ethernet lead to the Sky+ box😉
