4
This discussion topic has been answered Discussion topic: Move main box
This message was authored by: Leah04
Move main box
Hello
we need our main box moving to another room, can this be done
This message was authored by: Mark39 Answer
Re: Move main box
Yes. You can either buy a diy satellite cable extension kit which connects to your existing dish cables and run them through to the new room, or you could ask a local satellite installer to reposition the cables from the dish straight to the new room. Sky no longer provide engineer support for Sky+ equipment so won't help with this.
Re: Move main box
Re: Move main box
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q, Sky Glass and Sky Stream
Yes, but you'll need to find someone to do it for you or do it yourself as Sky have dropped engineer support for Sky+ now
This message was authored by: bigbott
Re: Move main box
I only want to move about 3 meters where can I buy the extension kit have tried curry's
Re: Move main box
Online via Amazon for example, or hardware stores such as Homebase, B & Q. Try googling 'satellite cable extension kit'
