Discussion topic: More top picks not loading
This message was authored by: Angie193
Top picks not loading, says if after 5 mins press yellow, done all that it says wn5 area
Re: More top picks not loading
Hi @Angie193   I suspect it is just you, I would try power rebooting your box.
Avatar for Angie193
Hi yes tried rebooting many times
This message was authored by: nuttybaglady
Sky HD boxes no "top picks" on TV planner since last week
I just get a message stating 'Searching for listings. Please wait. If you have seen this message for more than 5 minutes, press 🟡 for help'. Used the 🟡 and followed instructions numerous times to no avail. Starting to wonder if all these recent 'issues' are just Sky trying to get people to upgrade at a cost.
Re: Sky HD boxes no "top picks" on TV planner since last week
Most likely there wouldn't be a cost to upgrade. Have you tried restarting your Sky box by switching off at the plug for 4 minutes?
Yes. I have tried that as that's basically what the 🟡 button tells me to do.
How long as it been like this as I usually find that if you just leave it then it will return after a while.
What are your Signal Strengths/Qualities? Take a look at the link below:
Question Q11 in my Sky Plus F⋅A⋅Q
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Signal strength is around 75-100% based on the Settings menu. It seems to have been like this with the missing Top Picks for around 4-5 days. Just concerned new series may be starting or things of interest and ever since Never Miss was shut down I use Top Picks.
This message was authored by: jewers
I have the same message on my Sky+ HD box and can not access Top Picks.
This message was authored by: welsh.red
Not just you both my boxes exactly same been like for nearly a week,  suggestions working fine so not box or broadband has to be a sky issue.
This message was authored by: straps
we have 2 sky +hd boxes no top picks featured menu on both but can  get suggestions menu have been
turning both boxes off at the mains
Same on my box, so suspect it's an issue at Sky's end. It's not something I often use so couldn't say how long it's been like it.
Note to others - This is when selecting the 'More Top Picks' Tile from the Home Page
** EDIT - Similar reports on Sky Q Forum too.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
I think the posts on the Sky Q forum and in the wrong place and relate to Sky HD. One of them mentions pressing Yellow but Sky Q doesn't use the colour buttons within the EPG interface.
Avatar for Angie193
@welsh.red  pain in **bleep** as I was trying rebooting and all that it said, tried ringing but all I got was a dammed automated to contact sky protect
