Discussion topic: Poor signal for some of the sprots channels
This message was authored by: JP1289
I am receiveing a very poor signal and cannot watch today's EFL game. Most other sky sports channels are fine. Is anyone else having similar issues ? I have tried all the ususal stuff to rectify bit with no success
Re: Poor signal for some of the sprots channels
Signal issues usually indicate an issue with one or more of the following:
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
