Discussion topic: Installation sky Q plus box
This message was authored by: MargaretFullert
I have received a text msge to arrange an appointment with the engineer.
Avatar for MargaretFullert
Re: Installation sky Q plus box
Yes
@MargaretFullert give Sky a call to arrange it. We're customers here, like you, not Sky personnel.
By the way, it's just Sky Q, no Sky Q+ (just so you know)  🙂
@MargaretFullert
We are mainly customers on here trying to help other customers and you aren’t directly contacting Sky Customer Services.
Unless there's a dedicated phone number on any correspondence you've had you'll need to call Sky to arrange.
From a Sky Talk landline or a Sky mobile dial 150 to call Sky (free) or alternatively use this link:
https://www.sky.com/help/home
UK customers: Scroll down and click on ‘Need more help’ and a dedicated 03** UK number is displayed.
ROI customers: change the flag in the bottom right corner of the link to the ROI flag then scroll down and click on ‘Need more help’ and it provides a dedicated 0818 ROI number.
(The forum doesn’t allow us to type the numbers in full).
Similar to calling other large companies the start will be automated which may also try to send you here to the forum. Stay on the line as long as possible and don’t hang up. If necessary say nothing when the automated system asks you what your call is about as it should then route your call into a queue for the next available agent.
