Discussion topic: Mini TV unavailable no signal strength
This message was authored by: katiegal
I can't get any TV channels I have no signal strength mini TV unavailable no satellite signal
. All working ok until recently I have no contract and sky hd box
Re: Mini TV unavailable no signal strength
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
I am NeurodivergentMy F•A•Qs: Sky GlassSky StreamSky GoSky Plus
