Discussion topic: Input 2 signal strength loss
Message posted on 28 Mar 2026 03:14 PM
It is Input 2 strength and quality giving problems. Input 1 lock indicator is okay but Input 2 lock indicator says not locked and restricting us recording/changing channels,
Message posted on 28 Mar 2026 03:22 PM
Re: Input 2 signal strength loss
"No Satellite Signal" is an error generated by your Sky box, it has nothing to do with broadband (Internet connectivity) and usually indicates an issue with one or more of the following
- The Dish is misaligned (not all transponders are getting through, thus some channels may be affected and others not)
- The Tuners in the sky box
- The input sockets on the Sky box
- The plugs on the cables
- The cables themselves
- The Sockets on the dishes LNB
- The dishes LNB has gone faulty for the connections the box is using
- You have plugged your Sky+ box into a dish that is only compatible with Sky Q
Please Note: Sky+ is now a legacy/obsolete service that Sky are replacing with their newer services: Sky Glass and/or Sky Stream
You may have to call out a local satellite installer ( at your own expense ), unless you already have Sky Protect insurance, to check/fix your system, another option is to move to Sky Glass and/or Sky Stream (self-install, no engineer required)
Further help: https://www.sky.com/help/articles/sky-tv-no-satellite-signal-sky-plus-error-message-broken-image
