Discussion topic: I’ve had no sky signal for 3 days
This message was authored by: MaureenF690
I've had no signal even though I reboot the hub every day several times a day.
Re: I’ve had no sky signal for 3 days
No Signal or No Satellite Signal?
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
I am NeurodivergentFAQs: Sky Glass Sky Stream Sky Go Sky Plus
@MaureenF690
What TV service do you have, is it Sky+, Sky Q, Sky Glass or Stream ?
@MaureenF690  Rebooting your hub won't have any effect if you have Sky+ or Sky Q as all live channels are delivered over satellite not your broadband.
