Discussion topic: Prime Installation on Sky+
This message was authored by: Caz671
How do you install Prime on Sky+
Re: Prime Installation on Sky+
You cannot
@Caz671 Prime runs in an app. Sky+ boxes aren't capable of hosting apps. You would need to upgrade to Sky Q or Stream, either of which can support apps.
This message was authored by: Ellie_TV
@Caz671
Or, if you have a smart TV, the Prime Video app may already be installed on it. The app itself is free, but you need to subscribe to Prime Video via Amazon in order to view the content on it.
Avatar for Caz671
Thanks everyone. I thought that might be the situation!
