Discussion topic: How do i upgrade sky hd + box
This message was authored by: jacqueline59
How do I upgrade sky hd box
Re: How do i upgrade sky hd + box
Upgrade to what?
I am NeurodivergentMy Sky FAQs: Go Stream Glass Plus
Avatar for jacqueline59
Red button or text on sky remote not working
Please Note: Sky+ is now a legacy service that Sky are replacing with their newer services: Sky Q (all issues will be fixed during a Sky Q install), Sky Glass and Sky Stream
You would need to move to one of Skys other services mentioned above
@jacqueline59 As far as I'm aware, none of Sky Q/Glass/Stream carry the BBC Text service anyway.
If you locate BBC1 Yorks in the 950 range of channels it should work, but it might be the case that it's being withdrawn (by BBC) completely.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
@jacqueline59 Appears to be fixed.
