Discussion topic: I am having a problem resetting my Sky Parental lock pin.
This message was authored by: Paul346
I am still using Freesat from Sky but am unable to reset the Parental lock PIN. I still have the Sky card in place and have tried using the last 4 digits but that doesn't work. I have tried looking in My Sky but can't see a record of my Sky card on there even though I've had it for over 10 years. I have looked in the secret Engineers menu but can't find anything on there either.  Any idea where to go next?
Re: I am having a problem resetting my Sky Parental lock pin.
If you have a Sky+ box then try services > system details for your viewing card number.
Avatar for Paul346
Yes I have the card number from the Settings but entering the last four digits still doesn't work
That would imply that at some point you've changed it.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
