Discussion topic: How do I access HBO Max content on a Sky+ HD box.....?
Message posted on 27 Mar 2026 03:36 PM
Re: SKY+ HBO max activation
Thank you Mark, what about SkyGo?
Message posted on 27 Mar 2026 04:01 PM
Re: HBO Max is Now Included in Most TV Packages!
I have to say I lije Sky and have been a customer since forever.
The HBO launch is truly awful on a Sky+HD box!
Just a long list which you have to scroll through. No ability to put a search string like the new Paramount addition.
Cannot use the general search box to find anything on HBO. Basically useless I'm afraid. 😞
Message posted on 27 Mar 2026 04:18 PM
@Cathotel wrote:I have to say I lije Sky and have been a customer since forever.
@Cathotel There's a thread on the Sky+ Forum discussing exactly this
https://helpforum.sky.com/t5/Sky/How-do-I-access-HBO-Max-content-on-a-Sky-HD-box/m-p/5238819#M165267
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Message posted on 27 Mar 2026 04:32 PM
You can't sign into any apps throught a Sky+ box. Only Q/Glass/Stream.
You're limted to a subset of content made available to you through your + box.
Message posted on 27 Mar 2026 04:33 PM
As with all similar apps - only *some* content is accessible via On Demand
Message posted on 27 Mar 2026 04:39 PM
@r0cketscience wrote:As with all similar apps - only *some* content is accessible via On Demand
The pre-release info for HBO Max said All content would be available through Vod.
Message posted on 27 Mar 2026 04:48 PM
Usually you would be correct @r0cketscience but that might not be the case with HBO Max where all content should be available.
Message posted on 27 Mar 2026 04:49 PM
Re: How do I access HBO Max content on a Sky+ HD box.....?
Subtitles not working properly.
When there are 2 lines of them, the 1st line is partially hidden by the 2nd one and difficult to make out.
Never seen this on any other channel before.
Message posted on 27 Mar 2026 04:52 PM
Try reporting it to viewerR@sky.uk (Viewer Relations Team)
Message posted on 27 Mar 2026 08:18 PM
The Pitt s1 has appeared on the CatchUp section! Finally!
Message posted on 27 Mar 2026 08:53 PM
@JenS2 wrote:The Pitt s1 has appeared on the CatchUp section! Finally!
Excellent! There's quite a bit of extra content that wasn't there earlier.
Message posted on 27 Mar 2026 10:11 PM
Episode 3 (9AM) doesn't appear to be there that I can see.
Message posted on 27 Mar 2026 11:01 PM
@caesarome wrote:Episode 3 (9AM) doesn't appear to be there that I can see.
Yes, you're correct. There are only 14 (out of 15) episodes listed. Hopefully it's noticed and added.
There is a separate Tile for The Pitt with ASL which does have all 15 episodes listed.
Message posted on 27 Mar 2026 11:09 PM
The ASL version seems to have 2 x 7ams and is missing one of the later hours. It feels very messy but hopefully they will.sort it out.
Message posted on 28 Mar 2026 05:46 AM
@oj01 wrote:Yes, you're correct. There are only 14 (out of 15) episodes listed. Hopefully it's noticed and added.
The missing episode 3 is there now.
