Discussion topic: Problem with hard disk drive message on screen. No access to on demand services
This message was authored by: HardDiskDrive
Message says: there is a problem with your hard disk drive.  Recordings, on demand and other sevices are not available. I've tried the recommended fix but still saying there is a problem
Re: Problem with hard disk drive message on screen. No access to on demand services
Try a Planner Rebuild
See question Q02 in my Sky Plus F⋅A⋅Q
Avatar for HardDiskDrive
Level 0 icon
Yes this is the issue
@HardDiskDrive can you clarify what issue you're referring to? Did the Planner Rebuild not help?
@HardDiskDrive
You have also posted on the Sky Q board so which do you have?
