Discussion topic: Hd channels
This message was authored by: Gw15
Hd channels
Some of my hd channels are not getting signal ie bbc 1 and itv
Re: Hd channels
If you're seeing a 'no satellite signal' the problem is most likely your dish setup. Unfortunately Sky no longer provide engineer support for Sky + systems unless you have Sky Protect,  so you would need to engage a local satellite installer to take a look.
Alternatively now might be a good time to upgrade to Sky Q or Sky Stream.
Avatar for Gw15
Re: Hd channels
Every other channel is working just not bbc hd or itv hd. All sky channels work
thanks
Re: Hd channels
thanks
Check the transponder the affected channels are broadcast on, dish alignment can affect specific transponders/channels and not others
Avatar for Gw15
Re: Hd channels
Many thanks
