Discussion topic: Hard disc problem
This message was authored by: Mohammedullah
Message posted on 19 Apr 2026 11:27 AM
Hard disc problem
Hi
the message is there is a problem with your hard disc drive on the tv so can't access anything
Find out more
Message posted on 19 Apr 2026 11:36 AM
Re: Hard disc problem
@Mohammedullah try rebuilding your Planner as described in the link. If that doesn't fix it, you'll have to try a full System Reset next (explained in the same link). The latter will erase your recordings.
