Discussion topic: HD channels
This message was authored by: Phill167
HD channels
Hi
my mum has and old sky set up, main box sky+ HD main box and an old white sky box as a multi room box. She can't any HD channels now and ask to phone. If I replace the box with a HD box will it solve it?
Re: HD channels
@Phill167  Yes but you might need to contact sky to re pair the card
Re: HD channels
Yes. You'll need to take the Viewing Card out of the old box and use it in the replacement. Then just pair the Card with the replacement box.
This message was authored by: HeathHayle
Re: HD channels
dont know if your internet savvy if you are I would I personally match up your viewing card and box on the internet because sky are really trying to push sky Q so it might be really annoying trying to do it over the phone just a thought
= Sky+ SD boxes x4 (pace bskyb 3100) ===
Re: HD channels
You still need to call to inform them of the change in box
I am NeurodivergentFAQs: Sky Glass Sky Stream Sky Go Sky Plus
Re: HD channels
@Annie+UK ah thats interesting so just matching up a viewing card to a HD box doesnt change the box type on the system then?
Re: HD channels
There is a danger that a box swap is not identified and thus the billing system may auto cancel the viewing card, it is safer to inform Sky and have the account manually updated
Re: HD channels
very true
Re: HD channels
Also, I would add, that it's possible that the viewing card that's only been in a SD Box might not have HD privileges. If so, that will need to be added by Sky.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
