Discussion topic: Got a new Sky+hd box one once contented it is asking for a viewing card for some channels
This message was authored by: Maria1954
I have just connect another sky plus HD box and it is saying insert a viewing card there is no place for a viewing card nor do I have one,
Re: Got a new Sky+hd box one once contented it is asking for a viewing card for some channels
@Maria1954  Sky plus is a legacy service which sky no longer sells or supports
getting a new one is pointless as it will not work with any existing sky plus setup you have
All Sky+ boxes have a Viewing Card. If this is a replacement box, your Viewing Card will likely still be in your old box.
If that is the case the viewing card won't work with a replacement box also
@SKY1992bf wrote:
If that is the case the viewing card won't work with a replay box also
You're right, it won't, because it can't be paired with a replacement box.
