Discussion topic: Remote Code for Panasonic TB-43W60AEY
Message posted on 03 Jul 2025 07:10 PM
I have found 3 codes that work the volume and turn off the Panasonic TB-43W60AEY tv, but none turn the TV back on. Has anyone found a code that works? I am using a supposedly OEM remote bought from Amazon, but the version number is missing so I'm unsure which one it is, although I've programmed it to work an older Panasonic tv using ver 9.
Message posted on 03 Jul 2025 07:54 PM
							Re: Remote Code for Panasonic TB-43W60AEY
If you turn on HDMI Control in your Sky box settings, and VIERA Link in your TV settings, does that turn your TV on and off?
Message posted on 03 Jul 2025 09:07 PM
There doesn't appear to be a Viera link option available. Certainly not in the setup options that I can see, and I don't recall seeing it when I did the initial setup of the tv. I'll look again tomorrow just in case I've missed it somewhere.
Message posted on 26 Aug 2025 03:57 PM
Would you be kind enough to tell me what those remotes controls codes are. I too am having problems with the same Panasonic TV. However l would be greatful Just to be able to turn the volume up & down Thank you
Message posted on 26 Aug 2025 04:00 PM
Thanks for making this thread available.
Hopefully we can all help one another out
Message posted on 26 Aug 2025 04:13 PM
@Kevin178 have you tried 0680?
Message posted on 28 Aug 2025 07:42 PM
Hi.
Try the following codes. Some of them didn't work and others had differing levels of success.
1695, 1664, 1678, 0678, 2505, 0254 or 0302.
I have written the code 2079 inside the battery cover and it isn't the code for the old TV so it may be worth trying that although I've no idea where i found it.
