Discussion topic: Giganet problem
This message was authored by: IanPool18
Giganet problem
Sky+ box won't connect to on-demand after changing to giganet fibre connection.
Re: Giganet problem
Tried using the WPS buttons?
Avatar for IanPool18
Re: Giganet problem
It is an Ethernet connection and not WiFi. Worked fine on the old BT copper broadband. Sky box doesn't have WiFi.
Re: Giganet problem
Have you rebooted your Sky box and checked the network tab in the setting?
I am NeurodivergentMy Sky FAQs: Stream Glass Go Plus
Re: Giganet problem
I have and the network connection is ok but the on demand connection is fail.
Re: Giganet problem
Try setting up a manual IP address on your router and Sky box, with ethernet it should have adjusted auromatically but networking is like witchcraft sometimes
