5
This discussion topic has been answered Discussion topic: My remote won’t turn on my sky box, batteries are ok. Turned power supply on and off still a no go
This message was authored by: Olbe
My remote won't turn on my sky box, batteries are new. I've turned off the power and turned on again still no good.
This message was authored by: Mark39 Answer
Re: My remote won’t turn on my sky box, batteries are ok. Turned power supply on and off still a no
Have you tried switching off your Sky box for at least 4 minutes?
Avatar for Olbe
Yes I turned it off for 2 minutes and it worked. Thanks
That's NOT at least 4 minutes though 😞
Turning the box off quickly does not let the electricity drain fully so the box does not fully reset
You've been lucky this time but in future turn it off longer 🙂
I am NeurodivergentFAQs: Sky Glass Sky Stream Sky Go Sky Plus
Avatar for Olbe
Ok thanks for the advice, appreciate your input
cheers
This message was authored by: AMT4
I've just done that and left it for five minutes and have had a positive result. Thank you
