5
This discussion topic has been answered Discussion topic: Freesat channels availability and numbering
This message was authored by: Spunglefoop
I'm still deciding whether my 83 year old father should keep his Sky Q box and haggle Sky down to the most basic package because he's really not using the subscribed channels and services, not to mention money is really tight for him unfortunately.
Instead, I've obtained a Sky+HD box for him to use to just watch Freesat channels, after replacing the LNB.
I've noticed that the channel numbers on Freesat don't correspond with Sky's TV Guide, which I guess is expected.
Is there a way to reset the box to have Freesat's channel numbers or doesn't it work that way?
In fact, is it possible to edit the guide manually by removing channels and renumbering them so that all that he sees is all that he can get?
Additionally, I've noticed Sky News isn't showing. Should it still be available on Freesat?
Does he need a viewing card inserted to receive certain channels?
Thanks very much and hope you can help.
This message was authored by: Mark39 Answer
Re: Freesat channels availability and numbering
Answer so far as I can provide them below. Others may be able to add more.
No, you can't renumber the channels. But you can set up a list of favourites in any order you choose
Yes, it's available on Freesat channel 202 (503 on Sky?)
Not to my knowledge
Not to my knowledge
Not to my knowledge
Sky News is 501 in HD or 881 in SD
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
Thanks, @oj01
@Spunglefoop Freesat is a specific epg service only available on Freesat boxes ... it can not be accessed on Sky boxes.
A Sky boxes without access to subscription gives access to FTA DSat channels using the Sky epg service and channel numbering!
If you want the  Freesat epg the cheapest option is a Manhattan Freesat box😉
This message was authored by: robsie
I have a Sky plus hd box with full chanel listing, you need a viewing card so you will have full line up and ability to record otherwise you will only have access to free to air programme's
