Discussion topic: Fault with signal
This message was authored by: Heather113
Fault with signal
Television keeps going off, say not getting signal.  Have reset everynight for over a wk, have even searched channels but still goes off every night and take ages for it to come back on then its ok.  Could be sky dish or my box
Re: Fault with signal
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
I am Neurodivergent Sky+HD  LG NanoCell TV  Xbox Series X  Raspberry Pi 5 (Debian Linux)
My F•A•Qs: Sky GlassSky StreamSky GoSky Plus
Avatar for Heather113
I think I need engineer to come as iv tried everything
@Heather113 as @Annie+UK posted there's no longer any Sky engineer support for Sky+ customers unless you have Sky Protect. You would need to engage a local satellite engineer to come and take a look.
