Discussion topic: No satelite signal on sky +
This message was authored by: Anam92
We have checked our wires. Reset the box and trouble shooted the issue. We are still getting the same message that we have no satellite signal
Re: No satelite signal on sky +
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
I am NeurodivergentFAQs: Sky Glass Sky Stream Sky Go Sky Plus
