Discussion topic: Error with Sky+ box
This message was authored by: Sally601
Error with Sky+ box
I have an error message on my Sky+ saying there is a problem with the hard disk drive and cannot record or watch on demand
Re: Error with Sky+ box
Try a Planner Rebuild
See question Q02 in my Sky Plus F⋅A⋅Q
I am NeurodivergentMy Sky FAQs: Stream Glass Go Plus
@Sally601 that's unfortunate. You could try rebuilding your Planner as explained in the link below. If it doesn't work, or you get a 'diskless mode' error, the next step would be a full system reset - in the same link.
If neither solves the problem, your Sky box has failed, I'm afraid, and you'll need to consider upgrading to Sky Q or Stream.
https://www.sky.com/help/sky-tv/sky-tv-plus/sky-plus-watching-sky-tv/sky-plus-recordings/articles/re...
This message was authored by: Flapp1
Says, problem with hard disc so can only use sky programs,  not able to watch recordings
@Flapp1 same problem, so see the reply immediately before your post.
