Discussion topic: Error "No Storage Device! what does this mean and how can I fix it?
This message was authored by Annie64 This message was authored by: Annie64
it's exactly as it states No Storage Device, I only have SKY HD, was working fine this morning then bang this message appears. How can it be fixed.
Re: Error "No Storage Device! what does this mean and how can I fix it?
Hi @Annie64
looks like you may have a hard drive failure.
If you have Sky+HD you are on the wrong forum.
This is Sky Q.
Please confirm and I will move you to the correct forum
Annie64
Yes, it's SKY+HD, sorry feeling very frustrated at the moment
This message was authored by Annie+UK This message was authored by: Annie+UK
Planner rebuild:
For Sky+HD boxes (DRX890/DRX895) with the latest software try the following instructions:
• Press SERVICES on your Sky remote control
• Go to Help
• Select Sky+ Rebuild
• Press SELECT (this will start the rebuild)
If the above does not work try the following (Note: the first 5 steps are better done whilst looking at the remote control as the feedback on screen can be confusing):
• Press 0 (very old boxes may need you to press 4 instead)
• Press 0
• Press 1
• Press SELECT (You should now be in the hidden menu)
• Press 7 (Sky+ Rebuild)
• Press SELECT (An on-screen message will be displayed)
The above and so much more can be found in my Sky+ FAQ
Annie ( I am Neurodivergent ) - Sky Plus FAQ - Sky Stream FAQ
This message was authored by Mr+Flibbles+86 This message was authored by: Mr+Flibbles+86
Posted by a Sky employee
Hi there, I will escalate this to our community chat for you. Please look out for an email or chat bubble. We look forward to speaking to you
Annie64
Hi, can't access anything on the sky remote, I've basically a blank screen with the error message showing
This message was authored by Tom-W19 This message was authored by: Tom-W19
Hi Annie64
An invite was sent but there was no response within 48 hours so it has automatically closed.
If you still need help with this please let us know by posting on the forum again and we will get it escalated through to us.
Tom
On average, new discussions are replied to by our users within 100 minutes
