Discussion topic: Constant red light on remote
This message was authored by: FrazerB
My Sky remote has a constant red light, nothing is working on the remote.
I've removed the batteries and the light goes off.
I've tried holding the select button for 30 seconds to reset it. Nothing happens, tried different batteries, light just remains constantly on.
Any ideas?
Re: Constant red light on remote
Are any of the buttons stuck down on it ?
See question Q26 in my Sky Plus F⋅A⋅Q
I am NeurodivergentMy Sky FAQs : Go Stream Glass Plus
Avatar for FrazerB
Not that I can tell
Avatar for FrazerB
Took it apart and cleaned it all, put back together now the light isn't coming on at all.
Sounds like you'll need to replace it. You can buy one from your local supermarket or hardware store, or more expensively via the Sky Accessories shop.
https://www.sky.com/shop/accessories
