Discussion topic: Pair sky viewing card with Sky + box
This message was authored by: Gmb1
How to pair viewing card with old sky + box
Re: Pair sky viewing card with Sky + box
What sort of old Sky+ box?
Try performing a New Install
See question Q21 in my Sky Plus F⋅A⋅Q
Additional help with your viewing card can be found here
I am NeurodivergentFAQs: Sky Glass Sky Stream Sky Go Sky Plus
This message was authored by: HeathHayle
@Annie+UK just to let you know the link to activate the channels just goes in a loop @Gmb1 I have found this site
https://www.sky.com/myaccount/tv/card-pairing not sure if that actually works but it goes through the process and says at the end it has maybe someone could verify it actually works
= Sky+ SD boxes x4 (pace bskyb 3100) ===
Which link as they all seem find from my end
@Annie+UK the "Additional help with your viewing card" link when you try it do you get as far as the page that asks you for your box information?
I now see the link you are referring to: https://activatemychannels.sky.com/activate
I have reported the broken link to Sky, they should be able to fix this
@Annie+UK yes thats the one and thanks really appreciate that and I bet so will a lot of fellow sky+ users
