Discussion topic: Connecting sky box th broadband
Message posted on 28 Dec 2024 01:24 PM
When I try to use catch up it tells me to connect my sky box to broadband
Message posted on 28 Dec 2024 01:35 PM
Re: Connecting sky box th broadband
If your Sky+ box is connected to your broadband then try a reboot of your Sky+ box and your broadband hub at the mains.
Message posted on 28 Dec 2024 01:42 PM
Have you used catchup successfully before?
Message posted on 28 Dec 2024 04:39 PM
@Dibbie wrote:When I try to use catch up it tells me to connect my sky box to broadband
What sort of Sky box do you have?
Message posted on 03 Jan 2025 05:07 AM
This has just started to happen to me too. I'm wondering if I need a new WiFi adapter? My hub is working fine as my other devices are all working fine. Tried turning off box and rebooting - many times!! Adapter still won't pair. Any help gratefully received-thx
Message posted on 03 Jan 2025 08:54 AM - last edited: 03 Jan 2025 09:00 AM
There are no new Mini Connectors, given they haven't been manufactured for about a decade. You should be able to source a replacement on eBay for a few pounds.
With a white Max Hub you may need to reduce the wireless security level from WPA3 to WPA2-PSK using the Hub settings in the My Sky app.
Message posted on 03 Jan 2025 06:27 PM
Thanks. That's useful information. I have found reconditioned connectors on eBay for about £22. Mines a real old HD+ box and when updates come in it takes hours to reset it. I'm guessing that I need an update but a SkyQ will require an adapter on the communal dish (it's a block of private flats) which the freeholder won't give permission to having put on. The only alternative is Sky Glass I'm guessing?
Message posted on 03 Jan 2025 07:14 PM
@Kingswood+Ranger wrote:Thanks. That's useful information. I have found reconditioned connectors on eBay for about £22. Mines a real old HD+ box and when updates come in it takes hours to reset it. I'm guessing that I need an update but a SkyQ will require an adapter on the communal dish (it's a block of private flats) which the freeholder won't give permission to having put on. The only alternative is Sky Glass I'm guessing?
Sky+HD Boxes haven't received any software updates for well over 12 months.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
