Discussion topic: Can’t connect new sky hd remote to sky box
This message was authored by JSp1970 This message was authored by: JSp1970
I've got a new sky +hd remote as the select button on my previous remote isn't working. I've managed to sync so it can control volume and power on TV but nothing else- any help appreciated!
This message was authored by Annie+UK This message was authored by: Annie+UK
Re: Can’t connect new sky hd remote to sky box
You could have most likely fixed your old remote by taking it apart (1 screw) and cleaning the PCB and rubber button pad, my FAQ has instructions 🙂
This message was authored by Mark39 This message was authored by: Mark39
@JSp1970 @Is it a Sky+HD box that you have, or an older box? A Sky+HD remote should control a Sky+HD box without changing anything
JSp1970
It's a sky +HD box
This message was authored by Fayod This message was authored by: Fayod
I have this same issue but with a sky digibox (non-recording) would you have any suggestions for this? ☺️ thanks
@Fayod a Sky+HD remote can be configured to control non-recording digiboxes by doing the following:
1 Press "TV"
2 Press and hold "Select" and "i" together until the red LED flashes twice
3 Press "0" to operate a standard digibox box
4 Press "Select" - the red LED should flash twice
5 Press "Sky"
This message was authored by SRM1 This message was authored by: SRM1
Worked fine thanks
On average, new discussions are replied to by our users within 100 minutes
