2
This discussion topic has been answered Discussion topic: Hi, My Sky+ HD box is saying it is not getting a satellite signal.I have tried turning it off at the
This message was authored by: PaddyB67
Hi, My Sky +HD box says it is not getting a satellite signal. I have tried switching it off at the mains and checked all connections but no joy??
This message was authored by: Annie+UK Answer
Re: Hi, My Sky+ HD box is saying it is not getting a satellite signal.I have tried turning it off at
Please Note: Sky+ is now a legacy service that Sky are winding down
• The Tuners in the sky box
• The plugs on the cables
• The cables themselves
You may have to call out a local satellite installer, unless you have Sky Protect insurance, to check/fix your system, another option is to move to Sky Q, as during the move all issues will be resolved as part of the install, there is also the option of Sky Glass or Sky Stream, if you want to move away from satellite TV and use the Internet
I am NeurodivergentMy Sky FAQs: Glass Stream Go Plus
Sky no longer supports Sky+ boxes so you will have to contact a company local
to you so they come out and look into this for you.
