Discussion topic: CONECTION TO SKYBOX+HD FAIL
Message posted on 03 Dec 2023 08:55 PM
Hi All, We run an old Skybox+ HD in our living room and we run a virgin media router upstairs sky wifi went off and we tried to put it back in nothing, had to do a Skybox reset, having done this we have a Skybox that won't connect to wifi, in the network it says >
connection to broadband router fail
connection to on-demand fail
IP address of this sky box 0.0.0.0
DHCP on
in where the IP stuff is there's nothing in it so what do we do now ? wondering if the box is broken.
help please doing a manual IP configuration does nothing.
Message posted on 03 Dec 2023 09:01 PM
Re: CONECTION TO SKYBOX+HD FAIL
Try connecting by pressing the WPS button on the front panel of your Sky box, and within a minute, the WPS button on your Virgin router.
Message posted on 06 Dec 2023 12:29 PM
Hi. Tried to push wps on small box on top of sky+HD box then go press virgin router still get same msg there were no network, so try to press green button to put in by manual and now get four lines in network:
IP address of this router
All these are blank?
