Discussion topic: BBC 1 & BBC 2 no catch up on both my Sky HD plus boxes
This message was authored by: Neal+Bunker
Re: BBC 1 & BBC 2 no catch up on both my Sky HD plus boxes
Really annoying isn't it? Pay them your subscription and get shocking service.
Avatar for tillyboo
Level 3 icon
This message was authored by: tillyboo
I sent a tweet & tagged Sky in it, but so far no response
This message was authored by: Nutkin26
Hi, I doubt you will get a response it is a dispute with the BBC they won't let sky show old programmes they want everyone to use iplayer.
Hazel Wakeling
Avatar for tillyboo
Level 3 icon
Its not the point of what we want to download, its why a service which was ok is now not working.
If the service as been stopped, then fine, but tell customers/viewers, instead we're being told to reboot, turn things on/off, ringing Sky etc
If its no longer available to Sky HD + viewers, then BBC/Sky should make a statement
Hi, We are talking about catch up for BBC the only programmes available are today's.
Hazel Wakeling
Odd,  though,  that downloads of Eastenders would work OK, znd other progra,,es not. Seems unlikely that a blanket ban by the BBC has been put in place.
So there's clearly a glitch behind the BBC Catch Up Tile (I've reported it to Sky), but the programmes are there and available to Download, you just have to Search for them until it's fixed.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
We can only assume other shows aren't working but no-one has yet been willing to say what they're trying to download. It may be that the programme, whatever it is, is available when manually searched for.
Content can be found by searching as I mentioned this a week ago, for me this is quicker than going through the menus to locate the content.
I agree,certain programmes can be searched for,what the gripe is,is that If you go to a certain day on catch up,there is no programmes there,yet itv,channel 4 and 5 are there,why not bbc1 or 2,that is the crux of our problem.
I agree, I never use the Catch Up Tile which is why I didn't fully understand what the issue was. It's far quicker and easier to use Search when wanting to Download anything.
As asked before, what programs can not be found as still nobody has given an example ?
The point we are trying to make is not about certain programmes,it is about the service not being available,I get your point about searching for them,my point is why is the service not working now when it has been previously,ie go to catch up and try and find for example bbc1 or 2 in yesterdays listings,they do not appear! Yes if you search you will get most programmes but not all.
It doesn't sound like the BBC are actively blocking catchup programmes, then, as previously suggested. Nor is it impossible to download them, albeit you have to find them by searching rather than via a listing. If you have specific examples of programmes you can't find this way, you could raise them with the Viewer Relations team.
I have had 4 e mails off sky over the weekend,they are aware of the problem and have said to me that it should all be sorted by tomorrow,let's wait and see.
