14
This discussion topic has been answered Discussion topic: Additional Channels not found or disappeared
This message was authored by: Chief4me
We had some regional channels and other channels added to 'Other Channels' in the Option menu.
Today they all just went off/gone.  They cannot be retuned but comes up with ' no channels found' or the channels come up with a blank screen.  Looks like something has been switched off / shut down as everything else is working OK.  I think Sky do not want subscribers to add other channels.  Has anyone else found this or got a solution?
This message was authored by: xenon81 Answer
Re: Additional Channels not found or disappeared
Granada and ITV2 are now both on:
11386 H
27.5
2/3
DVB-S2
8PSK
There are several ITV1 HD regions on that frequency so you will need to check during local news to find out which is Granada.
Remember to delete the old label first, otherwise the new one will not appear when you enter the tuning details as it thinks the channel is already stored.
You will have to give a list of the channels and their tuning details.... they may no longer be broadcasting😉
Lots of ITV channels have changed frequency today. If you let us know which channels/regions you're looking for someone will be able to provide the new tuning details.
This message was authored by: Captain+Choas
I'm looking to retune Anglia East. At least I still have it on Freesat.
For manual tuning Anglia East is now on:
11386 V
27.5
2/3
DVB-S2
8PSK
Anglia East, Yorkshire East and Border England are on that frequency and all labelled "ITV1 HD" so you will need to tune in during the regional news to find the right region.
If using Sky Q delete the old channel from your list before tuning in the new one.
Avatar for Chief4me
I got Granada back but it went again saying there was a technical problem with channel. Now I can't put in any frequency or scan for channels.
This message was authored by: Stuwu10
New frequency info for manually tuning itv2 on sky q Ireland please.
11386 H
27.5
2/3
DVB-S2
8PSK
Avatar for Chief4me
Great thanks got there in the end. Just have to wait to find out which channel is which. I assume it is all HD now and no SD.
This message was authored by: Mich0804
Anyone got the new frequency for ITVBE? Thanks
Avatar for Chief4me
ITV BE HD.
I think it is  11386 V
                        27500  2/3
                         DVB - S2
                          8PSK
Hope that works.
It worked thanks so much 👍
Avatar for Chief4me
Excellent!
There are several sites online that list all the channels available with their frequencies etc. as I have found.  Might be worth looking into.
This message was authored by: SS92
Thanks for your help. Would you have codes for +1....in particular ITV3+1
@SS92
https://rxtvinfo.com/itvstvutv-satellite-manual-tuning/
