Discussion topic: Adding another sky+ box to current contract
This message was authored by: Manicpob
Does anyone know how many sky+ boxes I can have in my home? Tried searching on Google and it's says 4. But I cannot see anything on Sky to confirm this.
Re: Adding another sky+ box to current contract
Sky doesn't sell Sky+ boxes now so if you want extra you would need to upgrade to Sky Q.
@Manicpob  it is unlikely sky will allow you to, as sky plus is now a legacy product, you would need to switch to q for additional boxes
Avatar for Manicpob
Thanks.
You can buy your own used Sky+ box(es) cheaply from the likes of ebay, and use them to receive (not record) the free to air channels. You won't be able to buy an additional subscription to enable the recording feature or any subscription channels.
As to the number - the limiting factor is how many spare ports there are for use at the LNB (the bit on the arm of the dish where the cables connect). Each additional box will require a connection to one port. Obviously you'll need to install cabling from the LNB too.
Avatar for Manicpob
Thank you for the I formation.
